The Oliver Difference
Built on a Simple Belief
That a travel trailer should be built to last a lifetime — not just a warranty period. That craftsmanship matters. That buying direct is better. That Tennessee can build the finest fiberglass travel trailer in America.
Hohenwald, Tennessee. 2007.
Oliver Travel Trailers was born from frustration. Frustration with travel trailers that rotted from the inside out. With stick-built walls that leaked and delaminated. With aluminum frames that dented and corroded. With manufacturers who prioritized production speed over build quality.
The founders asked a simple question: what if you built a travel trailer the way you'd build a boat? With a complete fiberglass shell — not just a fiberglass skin over a wood frame. With two shells bonded together for maximum strength and insulation. No wood. No rot. No compromise.
The answer was the Oliver Legacy Elite — and it changed everything for buyers who were done settling for less.
Our Journey
Oliver Travel Trailers is founded in Hohenwald, Tennessee with a simple mission: build the best fiberglass travel trailer in America.
The Legacy Elite is introduced — the first production double-hull fiberglass travel trailer built factory-direct to the consumer.
Oliver launches the online owner forum, building one of the most engaged RV communities in the industry.
The Legacy Elite II debuts, offering a larger floor plan on a tandem-axle chassis for owners who want more space.
Oliver expands factory operations in Hohenwald, increasing production while maintaining the same hands-on craftsmanship.
Solar and lithium battery packages become standard options, cementing Oliver's position as the premier off-grid travel trailer.
Oliver continues to refine both models with updated technology, improved layouts, and next-generation features — all still handbuilt in Tennessee.
Come See It for Yourself
Tour the factory where every Oliver is built by hand.
Schedule a Factory Tour
