Four-Season Capability
True Four-Season Travel Trailers
Camp comfortably from Death Valley summers to sub-zero Colorado winters. Oliver's double-hull fiberglass construction creates a genuine four-season travel trailer.
Most manufacturers claim their trailers are 'four-season capable.' Oliver proves it. Our double-hull fiberglass construction delivers insulation, strength, and weather resistance that no stick-built or aluminum trailer can match — because the entire shell IS the insulation.
Double-Hull: Your Insulation IS the Shell
Oliver's patented construction bonds two complete fiberglass shells together with a structural foam core. This isn't fiberglass panels over a wood frame — it's a single, seamless thermal barrier that forms the entire structure of the trailer.
The result: R-value insulation that extends from floor to ceiling to walls, with zero thermal bridging from wood studs or aluminum framing. Heat stays in during winter. Heat stays out during summer. It's the same principle that makes fiberglass coolers outperform every alternative.
Double-Hull: Your Insulation IS the Shell Image
Enclosed & Heated Underbelly
Every Oliver features a fully enclosed, heated underbelly that protects plumbing lines, tanks, and mechanical systems from freezing temperatures. Hot air from the Truma VarioHeat furnace circulates through the underbelly cavity, keeping your water flowing even when it's well below freezing outside.
This isn't an aftermarket add-on or an optional upgrade. It's engineered into every single Oliver from the factory — because true four-season capability isn't optional.
Enclosed & Heated Underbelly Image
Truma Comfort System
Oliver equips every trailer with Truma's premium comfort system: the AquaGo instant water heater and VarioHeat furnace. The AquaGo delivers endless hot water on demand — no waiting for a tank to heat up. The VarioHeat provides consistent, whisper-quiet heating with multiple heat zones.
Both systems are designed for efficiency, running on LP gas with minimal electrical draw. They're the same systems trusted by European caravan manufacturers who build for genuinely cold climates.
Truma Comfort System Image
Dual-Pane Windows & Thermal Management
Every Oliver window is dual-pane acrylic — not single-pane glass. This dramatically reduces condensation and heat transfer, two of the biggest comfort killers in cold-weather camping.
Combined with the foam-core walls, enclosed underbelly, and efficient Truma heating, the total thermal management system keeps the interior comfortable and dry in any conditions. Oliver owners regularly camp in single-digit temperatures without issues.
Dual-Pane Windows & Thermal Management Image
FAQ
Frequently Asked Questions
What makes a travel trailer truly four-season?
A true four-season travel trailer needs: fully insulated walls, floor, and ceiling with no thermal bridges; an enclosed and heated underbelly to protect plumbing from freezing; dual-pane windows to reduce condensation; an efficient heating system; and construction materials that don't absorb moisture. Oliver's double-hull fiberglass construction delivers all of these as standard.
Can I camp in sub-zero temperatures in an Oliver?
Yes. Oliver owners regularly camp in sub-zero temperatures. The double-hull fiberglass insulation, enclosed heated underbelly, Truma VarioHeat furnace, and dual-pane windows work together to maintain comfortable interior temperatures even when it's well below freezing outside. Many owners camp year-round in northern climates.
How does Oliver compare to other four-season trailers?
Most "four-season" trailers use stick-built construction (wood framing with fiberglass panels), which creates thermal bridges at every stud. Oliver's double-hull design eliminates thermal bridges entirely — the foam-core fiberglass shell IS the insulation. This is a fundamentally different and superior approach to four-season construction.
Do I need to winterize an Oliver travel trailer?
If you're storing your Oliver for an extended period without heat in freezing conditions, winterization is recommended. However, if you're actively camping and running the furnace, the enclosed heated underbelly keeps plumbing lines from freezing during normal four-season use.
Experience Four-Season Camping
Visit our factory and feel the difference double-hull construction makes.
